2001 Montero Sport XS 3.5l weak A/C
Old Jul 8, 2014 | 03:27 PM
Bloodhound1941's Avatar
Default 2001 Montero Sport XS 3.5l weak A/C
Hello everyone! Joined the forum in the hopes of working out a few issues with my trusty 2001 Montero sport xs. She's got the 3.5 4x4. The A/C is not nearly as cold as it should be. No refridgerant leak and compressor isn't locking up or having any issues. Any suggestions as to what I could do to try and get it colder?
Thank you in advance for any suggestions or advice you may have!
Old Jul 8, 2014 | 11:59 PM
akwhitebuffalo's Avatar
buy a cheap can of a/c recharge at a parts store, most likely they will show u how to use them or do it for you....very easy to do....buy one with a gauge it's helpfull...I happen to have done this a lot...most come with stop leak now adays also...no threat there, and dont buy that one brand is better then another...its all 134a....
Old Jul 9, 2014 | 12:00 AM
just follow the directions and make sure ac is on max when charging....
Old Jul 9, 2014 | 01:09 AM
Does your Montero use R12 or R134 refrigerant? Do not use R134 in R12 system they are not compatible. I had to do the AC refill on an old (pre '90) vehicle and was faced with the same dilemma. In preparation for this project I talked to couple mechanics in town and did countless hours of web searches. The bottom line is - If you have R134 system then it is very easy - go to the parts store and get a 134 refill kit. After that it is pretty much Plug-and-Play. Very simple and straight forward.
However, if your system runs on old R12 stuff, you need a different approach. You have two approaches:
1. You ether have to go all out - drain and flush your AC system, replace evaporator canister and then refill with R134 and R134 compatible ac oil.
2. You can go with the stuff called R12a. It is a straight replacement for R12 but environmentally friendly.
I bought my R12a kit on Amazon - search for "RedTeK R12a". I've ordered a complete kit for my project. It came with 2 cans of refrigerant (you need to find out original AC system capacity and figure out if 2 cans is enough for you), 1 can of LeakStop and a fill gauge. The kit worked perfectly. Filled my system up and i got cold air coming out of my vents. I've been running my refilled system for about a month in the summer heat and so far it works without any hick-ups.
djbillyc
Jul 20, 2023 09:37 AM
JRK5892
Jan 2, 2015 06:28 PM
SRC1225
Jun 17, 2013 02:23 PM
mphil804
18
Jul 29, 2006 10:37 PM
dreamz
Dec 1, 2005 09:18 PM
