2002 montero engine removal
Hello I have everything but the torque converter off, my question is, how do I turn the torque converter so I can get each bolt out? Thanks everyone. I have tried turning it with a huge screw driver but didn't work
Take out the spark plugs, that will help when you are turning the engine. It might he3lp to have a helper turning the engine by the bolt on the front of the crankshaft pulley while you are under watching for each bolt to come up and take them out one by one.
I left all my plugs in with engine intact. I used a socket with extension and breaker bar on the crank pulley and rotated engine slowly clockwise till the torque converter bolt of interest came into view in the small access window then took it out. There are 6 torque converter bolts. Make sure you have a socket in excellent shape (6 point recommended) and fully seated as the torque converter bolts have a very thin heads and if you wring one off you are screwed.
How did you get the torque converter bolts off? I am having trouble getting them loose. As you mentioned I took the cover plate off and made access to the bolts. I tried different extentions and swivels, but none seems to work. Could you please let me know exactly what you used to get the bolts off? thank you for your help.
As far as engine removal tips, I tried to document as much as I could in my rebuild thread and on this one so study them carefully. The AC compressor you unbolt and put aside without cracking the freon lines. Don't forget the engine ground, various electrical connectors, etc.
TAKE LOTS OF PICTURES AND LABEL EVERYTHING!
I bought a box of 1 gallon zip lock bags and used a black sharpie to label all removed bolts and washers. Very particular on what went in which bag.
chrisdukelow
Apr 18, 2020 02:10 PM
mlahrens
Jan 29, 2016 06:54 AM
