2002 Montero Limited 6 cy Engine Problems
Old Mar 25, 2012 | 10:00 AM
LanceVincent's Avatar
Originally Posted by eco.ramon@yahoo.com
I have 233k miles on this truck bought it new. Recently had all the gaskets replaced now it's burning white smoke from the tail pipe and burning one quart every 1,000 miles. I had the thermostat, hoses changed and radiator flushed but the temperature gauge reads hot. Diagnostics does not show engine over heating. Can anyone help?
sounds like a similar problem i had, i had the thermostat, ect sensor and the guage itself replaced with no change. after a few months of research, i changed the pcm and the temp guage worked normal again, but the mileage was reset to zero. the pcm is inside the dash and cost almost 200 bucks
Old Oct 4, 2014 | 06:44 PM
Paul/Jimmy's Avatar
we have overheating on our montero 2002 limited ,all engine sensors working correctly,no service light coming,temp gauge clime
bs to 3 1/4,have no catalyst monitor,no evap system monitor,and no erg /vvt system monitor,when scanned temp is a 215 degrees.can you help with any other way this is over heating.
no leaks in cooling system aswell
look forward to your reply
rschoon
Jun 29, 2014 08:21 PM
marcmindte
May 31, 2006 11:08 PM
marcmindte
May 8, 2006 10:17 PM
NewYorkMontero
Dec 12, 2005 08:13 PM
firerice
Dec 1, 2005 07:13 PM
