2003 montero ltd ECM location
Old Aug 10, 2016 | 12:06 PM
LorenBateman's Avatar
Default 2003 montero ltd ECM location
Sry to start a new thread. Where is the location of the ECM
Old Aug 10, 2016 | 08:39 PM
Inside passenger foot well on the outboard side. If you get down there (under the glove box to the right), you'll see a bunch of wires going down behind a plastic cover on the outside wall. That is where PCM is located.
Old Aug 12, 2016 | 07:46 PM
Thank you Hunter, Had a few minutes to day and i see a plug bundle,, undid that but could not get that plastic cover out, i removed the screw at the bottom, but nogo, do you have any pics?
Old Aug 13, 2016 | 01:49 AM
I do not. I never had to pull the PCM out for testing. From the look of it, there is a plastic clip/plug on the floor that needs to be removed. There might be another one near the door. Then pop the cover off and you should have PCM exposed.
Old Aug 13, 2016 | 02:28 AM
ooops
Old Aug 13, 2016 | 02:41 AM
ooops
Old Aug 13, 2016 | 02:47 AM
[IMG][/IMG]
this pic needs to be rotated so the foam is at the bottom, this is the right kick panel, or is it under the floor board. Thanks again for your time Hunter. I have removed the two large plugs but can not remove that plastic piece
Old Aug 13, 2016 | 04:02 PM
I think the black handle looking thing is the lock. It may need to be moved to one side or the other.
Old Aug 13, 2016 | 10:19 PM
i did that and removed the two plugs, there is nothing behind it,, i tried to remove the male sockets and take out the large piece of plastic but could not get it to come out
Old Aug 14, 2016 | 05:17 PM
guangui's Avatar
Sending it to have it repaired??? Send me a private message, and I will send you a link for the repair manual.
humhai420
Mar 30, 2009 11:09 PM
wildside
Jan 8, 2007 03:36 AM
flash3546
Sep 14, 2005 06:38 PM
heling
May 11, 2005 09:52 AM
JTE7690
Nov 15, 2004 05:18 PM
