2WD/4WD Indicator - Only one rear wheel lit?
Old Feb 19, 2006 | 11:53 PM
jcasaccio's Avatar
Default 2WD/4WD Indicator - Only one rear wheel lit?
Hi-
I just noticed today that only one rear wheel is lit on the indicator, whether I am in 2WD or 4WD. Is there some sensor that is malfunctioning, or is just the little light burned out? Anyone else have this ever?
Jack
Old Feb 20, 2006 | 04:45 AM
off roader's Avatar
Default RE: 2WD/4WD Indicator - Only one rear wheel lit?
Jack,
Is your rig a Montero or Montero Sport? Which model and what year would be extremely helpful. I'm not 100% sure but it's probably just a burnt out bulb especially if it's a rear light. I know for sure Gen I & Gen II montero's don't have any rear wheel sensors for 4WD because it's a mechanically engaged coupling, and not an electronic one. The only time you won't have a rear wheel engage will be from a broken transfer case gear (BIG DAMAGE.... never, ever heard of this happening) or a broken rear axle (possible but you'd probably know you have problems).
Old Feb 20, 2006 | 11:07 AM
jcasaccio's Avatar
Hi!
It's an 03 Montero Ltd. It drives fine, so I think it may be the bulb, but wasn't sure. Sounds like you think that's all it is.
Jack
Old Mar 23, 2006 | 12:33 PM
jcasaccio's Avatar
Took it to the dealer and it was in fact a bulb. They replaced it under warranty.
JRK5892
Jul 1, 2013 12:54 PM
Dsmoovy
Nov 21, 2011 03:00 PM
rush
Jun 6, 2011 11:17 AM
MooF
Sep 11, 2010 11:12 PM
thehintons06
Jan 15, 2008 04:10 PM
