4WD dash light wont come on
Old May 11, 2006 | 04:50 PM
mikeinfhaz's Avatar
Default 4WD dash light wont come on
I have a 2001 XLS and the 4x4 works, but the dash light doesnt come on. I dont imagine this light has burned out with only 40K- everything else lights fine and the previous owner never bothered to use the 4x4 (yuppies... grrr...)
Anyone else have this problem? Is it a sensor or anything technical? Thanks
Old May 11, 2006 | 08:00 PM
off roader's Avatar
Default RE: 4WD dash light wont come on
Are your front auto hubs engaging? i.e. is it in 4wd when you put it in 4wd?
Old May 12, 2006 | 02:12 AM
Joel_CA's Avatar
When you 1st start the vehicle, all of the bulbs should illiminate as a means of verifying it's operation. The ones that don't light up at that time is due to a failed bulb.
J
Old May 19, 2006 | 08:11 PM
mikeinfhaz's Avatar
yep, the light comes on very rarely. could be a faulty switch? I took the console apart and looked for any loose connections, as I said the light comes on once in a while. Is there a bad sensor somewhere?
mulder
Jun 5, 2018 01:00 PM
corsair_105
Oct 19, 2013 10:27 PM
Dsmoovy
Nov 21, 2011 03:00 PM
greengrounds
Jan 20, 2010 06:59 PM
diamante grandad
Jan 19, 2009 12:26 PM
