89 choke stays on.
Old Feb 13, 2015 | 06:22 PM
Jesse24's Avatar
Default 89 choke stays on.
My 89 montero 4 cyl has a high idle when cold. The choke stays on for 15-20 minutes. I assume it's choke, it stays at 2500 rpm. Temp gauge never reads past 1/4. Once really warm it will drop to a steady idle at 8-9 hundred. This can't be normal? I figured it was a thermostat stuck open, but that isn't it, new one just installed and same problem. It's as if the car thinks it isn't warm but heat blows hot, and engine is def at operating temp. Thoughts?
Old Feb 13, 2015 | 07:13 PM
elboy0712's Avatar
Default coolant temp sensor?
Not very familiar with that model year but have you checked your coolant temp sensor to see if its working? Total stab in the dark there.
Old Feb 14, 2015 | 01:37 AM
Akzle's Avatar
4 cyl what.
diesel? petrol? unicorn?
sensors. all of them.
Old Feb 15, 2015 | 04:32 PM
A choke on a diesel engine? I doubt it. On a unicorn that's another story - choke on a unicorn and you get a no go condition
Old Feb 16, 2015 | 01:05 AM
Akzle's Avatar
...well it might not be a choke issue at all.
the only thing OP actually knows is that idles high then drops.
"choking the unicorn"... sounds like somthing you might pay $200 an hour at the brothel for...
Old Feb 16, 2015 | 12:47 PM
Jesse24's Avatar
Thanks, I did the coolant temp sensor before anything else, and no dice. The is a second sensor on the thermo housing with a single wire. I'll try that next. Anyone know what that one is called? Thanks for help. Its a hybrid solar/ unicorn powered motor. Cutting edge tech for 89
Old Feb 16, 2015 | 03:17 PM
Try a whip on that unicorn
Old Feb 17, 2015 | 01:43 AM
Akzle's Avatar
try a different mix. i find mine fouls plugs at 25 unicorns:1 sun, but running it at 40:1 there's no problems.
Jesse24
Mar 9, 2015 01:50 PM
josenet
Jun 21, 2013 12:41 AM
03outlander
Sep 16, 2008 01:15 AM
salazar44
May 16, 2007 01:09 PM
EcLiPsEGrRL29
Sep 29, 2005 02:59 AM
