91 Montero 3.0 stuck in 4x4
Old May 2, 2024 | 12:24 PM
base4door's Avatar
What I hear is they are default 4wd.
I understand in many models it's a vacuum line that keeps a "clutch slave cylinder" type pin depressed
If the vacuum line works, 4wd can be disengaged, but if not because of whatever causation, it will not be able to let go of 4wd and will remain, even if 4wd stick is in 2wd.
Old May 2, 2024 | 12:30 PM
base4door's Avatar
Check yours for the cannister somewhere underneath near the transmission, or vacuum lines around a double solenoid (each an electrical plug about thumb size)
Not sure what you've got, but early years are likely to have canister (assumption) rather than the electrical + vacuum solenoids.
Look for a rubber boot , (and not the regular drive clutch slave cylinder boot for standard transmissions), find the boot that entangles with vacuum lines and that's definitely it.
best luck.
Old May 4, 2024 | 10:42 AM
monteroprospect's Avatar
best luck.
Theres the second res.
85 montero
85 montero Before
85 montero Undercarriage before
85 montero Engine bay
85 montero Drivers side where hose was disconnected
Nest of hoses
Umarkhan102
Jan 20, 2020 01:16 PM
Umarkhan102
Jan 8, 2020 02:49 PM
wilde
Jun 16, 2016 03:52 PM
mlduncan96
Jan 31, 2016 03:46 PM
donkeeh
16
Jan 29, 2007 08:31 PM
