93 sr 4wd changing rotors!?!
Old Jan 4, 2008 | 08:45 AM
Killer's Avatar
Default 93 sr 4wd changing rotors!?!
i've never had to take the rotors off of a 4wd vehicle before.... and started to do so last night, but couldn't figure out how to get them off!!!
i had taken the wheels/wheel locks/calipers/brake pads... i took the bolts out of the wheel bearing (but it wouldn't come off at all) and without the wheel bearing off(or atleast the plate that covers it) i can't get a socket/wrench/anything in to take the only other existing bolts off...
Old Jan 9, 2008 | 08:13 AM
Killer's Avatar
Default RE: 93 sr 4wd changing rotors!?!
no one knows how to do it???? i can't find anything on it...
Old Jan 9, 2008 | 12:59 PM
r1concepts's Avatar
if you have all the necessary bolts and caliper off and the only thing that is holding the rotor on is rust. Go get a mallet or use a hammer since you are replacing the rotors anyways. Butcher the damn thing out. Hit it north and south the rotor, it should break off.
Old Jan 9, 2008 | 01:00 PM
r1concepts's Avatar
also try using brake cleaner.
Old Jan 15, 2008 | 10:38 AM
Killer's Avatar
no, i mean as far as bolts and everything goes.... there are i think six bolts holding the wheel bearing cover on, we took those off and nothing would move.. the cover prevents me from reaching the other six bolt(nothing will fit in the space needed) which appear to be holding the rotor on.... then i noticed behind the rotor connected to each of those other bolts is a nut, well you can't get anything in there to hold the nuts still even if you could reach the other end of the bolt...
you following me??
Old Jan 16, 2008 | 07:19 PM
rcsays's Avatar
I'm guessing you already solved the problem since this was posted months ago. But I'll post the answer in case anyone else is suffering from the same situation... as I was earlier today. The solution is easier than you may think. Once you pull the cap off the end of hub assembly by removing the six bolts, you'll see a grease filled hub assembly. You need to remove the phillips head bolts that hold the outer ring to the jam nut. Then take the ring with several holes in it out. You can do this by using a small flat head screwdriver. Then you can remove the jam nut by either buying a special tool at the Mitsu dealership or Harbor Freight Tools OR do as I did and stick two screwdrivers in the two holes in the jam nut that are bigger than the two holes you just unscrewed the bolt from. Hold the handle of both screwdrivers in your left hand (assuming your are right-handed). Then put a tire iron or a handle of a hammer or anything else that's long and strong (Heh-heh!) and turn the jam nut loose. The jam nut should loosen easily since the whole hub assembly is loaded with grease.
To reinstall, I used the screwdriver trick again. You don't want to overtighten the jam nut because that will cause your bearings to wear prematurely. Just make it "finger tight" then give it about an 1/8th of a turn more. NOT TOO TIGHT!
I hope that helps!
One other piece of advice... you may need to buy new grease seals that will go on the innermost portion of the hub assembly. Sometimes when you're pulling the hub assembly off, you may need to remove them. Then they might not seal up well when you putt them back in. They're only about $3 each. So they're worth replacing.
Good luck!
Old Jan 21, 2008 | 01:44 PM
Killer's Avatar
thanks... this was actually just posted the other day.. so no, i never messed with it again and never took the rotors off...
BUT that was my problem, after taking the six bolts off the end of the hub essebly i coudln't get that cap to come off.... at all.. it wouldn't budge...
seehow
May 12, 2015 05:08 PM
Dsmoovy
Nov 21, 2011 03:00 PM
greengrounds
Jan 20, 2010 06:59 PM
applewins
Apr 29, 2009 12:04 PM
Elitepinky
Aug 10, 2005 06:35 PM
