97 Montero Engine
I Have a 97 Montero with a engine with 135K that smokes quit a bit on take off. Has anybody had one of these engines rebuilt at the dealership? Aslo do you know what the cost of having this done? One last question if all else fails should I will buy a Already rebuilt one. Any help is appreciated.
The smoking is from the valve stem seals. They tend to wear out. They can be replaced on the engine without removing the heads, but it is difficult. If you replace them your engine will go another 100k miles. A '97 is one of the best year montero's out there. One other possibility is a product called Auto-RX. You can read about it at; www.auto-rx.com You can also find a lot of info at www.bobistheoilguy.com under the "additives" forum. It is only $25 and has gotten a lot of rave reviews.
If you want a new engine I would only get one from the dealer. A new block with heads is about $2300. If you take care of it it will go 200k easy.
rmplstlskn
May 13, 2022 02:49 AM
nicholsm
Dec 12, 2011 04:57 PM
anko_kun
Jan 17, 2006 11:52 PM
