97 Montero Engine
Old Jul 28, 2005 | 03:09 PM
Rumplecat's Avatar
Default 97 Montero Engine
I Have a 97 Montero with a engine with 135K that smokes quit a bit on take off. Has anybody had one of these engines rebuilt at the dealership? Aslo do you know what the cost of having this done? One last question if all else fails should I will buy a Already rebuilt one. Any help is appreciated.
Old Sep 14, 2005 | 12:17 AM
kawboy636's Avatar
Default RE: 97 Montero Engine
It's usually better to replace an engine or tranny with a rebuilt. It is quicker, easier, and cheaper to just swap out yours than pay to pull it apart and have it rebuilt.
Old Sep 14, 2005 | 01:51 PM
Winshawn's Avatar
The smoking is from the valve stem seals. They tend to wear out. They can be replaced on the engine without removing the heads, but it is difficult. If you replace them your engine will go another 100k miles. A '97 is one of the best year montero's out there. One other possibility is a product called Auto-RX. You can read about it at; www.auto-rx.com You can also find a lot of info at www.bobistheoilguy.com under the "additives" forum. It is only $25 and has gotten a lot of rave reviews.
If you want a new engine I would only get one from the dealer. A new block with heads is about $2300. If you take care of it it will go 200k easy.
Old Sep 16, 2005 | 12:42 AM
Rumplecat's Avatar
Thanks for the info I am still looking but the website looks pretty promising. Thanks for all the info.
rmplstlskn
May 13, 2022 02:49 AM
nicholsm
Dec 12, 2011 04:57 PM
schif_e
Jun 2, 2006 02:16 AM
m3kgt_99
Jan 31, 2006 05:25 PM
anko_kun
Jan 17, 2006 11:52 PM
