98 Montero TPS settings?? Please Help
Old May 25, 2010 | 10:54 AM
Jeff H's Avatar
Default 98 Montero TPS settings?? Please Help
I have a '98 Montero Sport V6. I just had to replace the Throttle Position Sensor and need to know how to adjust this?
Which of the 4 wires do I read off of with a meter and what "numbers" am I looking for?
Thanks so much, in advance.
Jeff
Old May 25, 2010 | 01:42 PM
jrmdir's Avatar
I bookmarked this some time ago. Not sure which Mitsu model it is for but most of the diagrams are identical to those in my factory manual for my '99 3.5V6.
http://www.3si.org/wiki/index.php/TP...sor_Adjustment
Hopefully some or all of this info will apply to your Sport.
Good luck.
Ron
Old May 25, 2010 | 01:46 PM
jrmdir's Avatar
Now I recall - that instruction link is for 3000GT. Hope the wiring set up is the same. Again. The instructions in my manual are very similar.
Old May 25, 2010 | 03:09 PM
Jeff H's Avatar
Thanks for the link. I will give it a try.
-Jeff
Old May 31, 2010 | 10:14 AM
antonio.rivelli@gmail.com's Avatar
Hellow folks. I have a Montero 1998 V6 3000. Would you know where could I find a manual with mitsubishi codes for parts and pieces and respective exploded drawings? I'd like to order some replacements from US (I'm in Brazil)and need this code to avoid mistakes. Additonally could you recomend me some parts suplyers there? thank you very much. Antonio
NGC1672
Mar 30, 2010 07:11 PM
Toshab68
Oct 12, 2009 11:16 AM
sammyboy02468
Jun 22, 2008 12:21 PM
monkey
Aug 27, 2005 03:07 AM
FARDJA
Jun 28, 2005 11:05 AM
