99 Montero OBD Code Help: P0421
Old Dec 15, 2006 | 03:00 AM
jrmdir's Avatar
Default 99 Montero OBD Code Help: P0421
Anyone have a handle on the problem behind this code? Defined as "Warm Up Catalyst Below Threshhold" but I've heard this may also be a result of faulty O2 sensor(s) My Montero has 132K miles on the original O2 sensors. Prior history of oil leaking on the forward sensors from the rear cam plug seals (recent new O-rings fixed that)
Advice/opinons appreciated.
Thanks,
Ron
Old Dec 15, 2006 | 07:47 PM
Manybrews's Avatar
Default RE: 99 Montero OBD Code Help: P0421
that code almost always indicates a failed cat. converter... its nearly 100 percent accurate.
Old Dec 18, 2006 | 05:49 PM
jrmdir's Avatar
Thanks for the info - I was afraid it might be more than the sensor. I have two cats - any idea how to tellwhether oneor the other, or both,are bad?
Ron
07outie07
Nov 6, 2016 06:29 PM
se7en
Oct 6, 2010 10:17 AM
Fe2O3
Feb 6, 2009 10:41 PM
jmil
May 12, 2008 04:21 PM
Stryker
Sep 16, 2007 08:36 PM
