Burnt insulation odor from a/c vents
Old Sep 2, 2006 | 06:21 PM
livetoride20000's Avatar
Default Burnt insulation odor from a/c vents
The theory of "threes". Wheel bearing first, now suddenly, while waiting for a light in traffic, a strong odor of "electric fire" (no smoke) coming from the a/c vents. I pulled over and looked under the hood - slight odor of the same under the hood, but man is it strong when I run the a/c. The Montee never did this before. Any ideas? I'm nervous about parking in my garage tonight so the ideas would be most appreciated and maybe life-saving. (2002 full-size Montero, LXS, 4x4, 64k mi with new $1200 wheel bearing
Went out to check the problem. If anything unpleasant was going to happen, I didn't want to be sleeping when it happened in the garage under my bedroom. Went for it. Engine on, turned the a/c up and fan on full. Smell got real strong for about 10 seconds, figured the problem was going to show itself soon, there was a sudden clicking sound under the hood - maybe from the compressor clutch - so I shut everything down. Started the a/c up again. Smell dissipated almost immediately. No clicking sound. No smell. Cooling nicely. All back to normal - so I believe.
Went out 30 minutes later and ran the a/c at full twist again - all good. No problems, noises or smells??????
Old Sep 3, 2006 | 03:06 AM
off roader's Avatar
Default RE: Burnt insulation odor from a/c vents
May still be something wrong and that was just the initial signs of it. I hope now but you never know. Would be a good idea to have your AC electrical parts checked out.
Also, if you've recently installed any modifications on anything (radio, compressor, anything...) it may have messed something up so check that first.
Old Sep 3, 2006 | 11:13 AM
i think the smell was the compressor clutch
Old Sep 3, 2006 | 11:34 PM
Thank you off roader and Sebba.
No new electrical parts have been added. Matter of fact, only significant work was the wheel bearing - sorry about the continuing reference to that. Would the "burning" odor be so strong "inside" what seems to be the vent system if the compressor clutch stuck. I would think it would smell stronger under the hood where the serpentine belt would smoke up rather than what appears to be inside the vent system which dumps into the passenger compartment. Just curious.
Also, what would cause a compressor clutch to stick or freeze up?
NOMAD5000
Apr 9, 2012 09:01 PM
piper
Jan 3, 2009 05:12 AM
Outlander_Joe
Aug 7, 2008 10:53 AM
Punisher
Feb 8, 2006 02:55 PM
Bona43
Nov 15, 2004 07:43 PM
