Changed timing belt & water pump now Montero won't start
Old Sep 8, 2007 | 10:44 AM
raycam2kx's Avatar
Default Changed timing belt & water pump now Montero won't start
I Changed the water pump, timing belt ( and other belts) and the auto tensioner adjuster. Now my truck won't start. I triple checked my timing marks and rotated the pulley at least 3 times to make sure the auto adjuster tightened the timing belt. When I first tried to start the truck it sounded like it was going to start but nothing just vrrrr...... Now it just won't start. Anyone experience this or know what my problem is.
95 Montero LS 3.0 122k
Old Feb 20, 2008 | 08:06 PM
killerkaw's Avatar
Default RE: Changed timing belt & water pump now Montero won't start
Are you ABSOLUTY sure that the crank was on the TDS (top dead center) on the #1. when you set the timing marks?
Old Feb 20, 2008 | 08:15 PM
dsm1990gsx's Avatar
Is everything plugged in? Do u have compression and what killerkaw said make sure timing is right.
Old Feb 21, 2008 | 11:08 PM
jgbrules's Avatar
hello! from many years of mitsu dealership expierience, 2 things come to mind. the wires going to the cam sensor are crushed behind the timming cover.secondly, did you have a real hard time getting the crank pulley off?? some times the crank sprocket will also slide forward when you are taking off the crank pulley and the crank sensor blade that is mounted to the crank sprocket will come loose, sometimes the blade will actually break the sensor in extreme cases. get a scanner and bring up the data in the MFI section and monitor the cam and crank sensors. which ever one isnt registering at least 200 RPM's when cranking is the culprit! good luck!! keep us posted!!
adamsstreetauto
Feb 23, 2018 05:43 PM
Wi_Fibre
Jan 16, 2008 12:17 PM
raycam2kx
14
Oct 6, 2007 08:31 PM
raycam2kx
Aug 16, 2007 08:33 PM
dsfii
May 10, 2005 03:08 PM
