Check engine light not working
Old Mar 20, 2011 | 10:54 AM
mikwya's Avatar
Default Check engine light not working
I have a 2001, Montero sport ES with 117k miles, check engine light is not working and it is not the bulb, Have a feeling that the place i bought from may have disabled it intentionally, I have checked all the fuses and they are all good but there are some that are missing and I can't find a diagram that tells me what they are, can anyone please give me some direction
Old Mar 20, 2011 | 03:37 PM
You need to find your ECU pinout diagram. Maybe look through a manual like Haynes or Chiltons to find that.
There is a certain pin on the ECU that pertains to the check engine light. When you remove it or cut the wire, you eliminate the light.
Old Mar 20, 2011 | 03:51 PM
mikwya's Avatar
ok is there a fuse for the ecu, my fuse box diagram not showing one and i have not been able to find a book anywhere locally
Old Mar 20, 2011 | 04:02 PM
No, there is not.
Look online for a service manual, you should be able to find one.
Old Mar 21, 2011 | 07:47 PM
mikwya's Avatar
Smile
ty, found a wiring diagram online and traced out the problem, you were right was a clipped wire under the dash that was very well hidden. Now i can work on the the rest of the problems in a new thread
guyjg
Nov 13, 2021 03:27 PM
kostovski.dragan
Jul 30, 2014 04:55 AM
pgb205
Jun 4, 2009 10:40 PM
c577
Oct 16, 2007 12:03 AM
bxdiamante
Jun 22, 2005 10:33 AM
