EGR sytem
Old Jun 4, 2020 | 03:12 PM
Gene's Avatar
Default EGR sytem
I get a generic p505 code have replaced 3 parts got better each time but now its getting worse ,I replaced one electric solenoid the idle air valve and the Idle air control valve.The vehichle wont start without stepping on gas but once warmed up its fine but after about 30-60 min it starts to hunt at idel between 250 and 300 rpm at stops and I here some kinda mechanical clutch kicking in back and forth? Anyone know or got ideas.Its a 2000 montero sport 3liter auto 4wd LS
Old Jun 5, 2020 | 07:21 PM
Gene's Avatar
Ended up being a stretched throttle cable ,but wondering what the ideal idling rpm is
Old Jun 5, 2020 | 09:02 PM
i think standard idle speed is somewhere around 700-800 rpm. Make sure you don't "control" idle with the throttle cable.
Old Jun 6, 2020 | 09:10 AM
Gene's Avatar
Oh why it was stretched and loose we adjusted and tightened?
Old Jun 6, 2020 | 11:07 AM
What I mean is - do not install throttle cable taught enough to affect the idle. Years ago, when I was working on another vehicle, it would not keep idle. The only way i can keep it from stalling at traffic stops was to keep gas pedal depressed while in neutral. That way it idle at higher RPM but not stall. Me, not in my smarter days, decided to outsmart the car. I tightened the throttle cable, so that the gas pedal did not return throttle plate to fully closed position. That worked for awhile, but once in awhile the engine would just rev up much higher at idle. I did some more poking around and found another part in the idle control system that was malfunctioning intermittently. That was why it would not keep "normal" idle. Once I got that part replaced, I relaxed throttle cable to specified slack and the car always had good happy idle on its own.
Old Jun 6, 2020 | 11:17 AM
Gene's Avatar
What was the part you replaced
Old Jun 6, 2020 | 02:42 PM
Idle control valve.
Old Jul 2, 2020 | 10:15 PM
Gene's Avatar
So now battery died alternator shot , replaced now idle speed is 1100 rpm omg
philthy360
May 16, 2020 12:35 PM
wadea
Jun 10, 2011 10:08 AM
drobjr
Oct 29, 2005 10:18 PM
FireDoc
Oct 13, 2005 06:07 PM
wadea
Jul 26, 2005 12:42 AM
