Help Idles Too FAST!
Old Mar 8, 2007 | 11:11 PM
pcbm's Avatar
Default Help Idles Too FAST!
Hi i've got a Montero sport LS 98 model recently started idling too fast. When I start it with the engine cold, it idles @ 17000 RPM's. As it warms-up, the RPM's gradually climb with the temperature to 1900 RPM's. Has anyone had this problem ?, or have any knowledge or ideas to cause of it. I'd sure like to hear from you. Regards [8D]
[IMG]local://upfiles/11683/47A3A7D29DF447C998CB7A55F9AE51D7.gif[/IMG]
Old Mar 8, 2007 | 11:46 PM
Default RE: Help Idles Too FAST!
Not sure if you have one... but some have a BISS screw on the throttly body that controls idle.
Old Mar 9, 2007 | 02:01 AM
pcbm's Avatar
Thanks for the suggestion ill be looking to that… in the morning
Old Mar 12, 2007 | 01:37 PM
Winshawn's Avatar
You should not need to adjust the idle on your montero. If it is unable to control the idle speed, it is probably your Idle Air Control motor. (IAC). It is a thing that sticks out on the side of the throttle body with 9-pin? plug connected to it. Search for IAC or ISC on the internet. You can purchase rebuilt ones.
dart6
Feb 16, 2011 09:25 AM
batholith
Jan 16, 2010 12:56 PM
ac777
Dec 5, 2007 04:25 AM
locoal619
Feb 6, 2007 11:52 PM
ram
1st Generation
Jun 12, 2005 12:02 PM
