How to Clean 94 Montero Sun Roof Drain Tubes
Old Mar 28, 2019 | 12:42 PM
  #21
Marksroberts61's Avatar
Default Down in back!!!
I have a pair of 95 SR's that are like this as well, plus experience with 4 more. If you get in the back and watch the rear of the glass, it will move up after the front seats against the roof (on a properly working one, that is). You may be able to push the rear of the glass up with your hand on yours and this is the proper closed position. I can't get mine to seat properly with the motor, so I'm just going to put in a couple of wooden wedges to hold it up until I delete the sunroof entirely. I figure I'll save about 80 pounds of weight up high where we don't want it when off roading, get that cg down some.
Old Mar 28, 2019 | 04:44 PM
  #22
1960StudebakerHawk's Avatar
Marksroberts61....Thanks for replying to my thread about the sunroof. I now have three 94s (2 SR and 1 LS), and all three are the same......the rear of the sunroof does not pop-up all the way flush with the roof. This is apparently normal, and all 3 of mine are not leaking. I did cleant the rubber edging and then applied warm Mineral Oil and let them bake in the warm sun, and I think that helps to restore the sealing rubber, maybe expanding it a bit and making it tight again. I also used it on the rubber on the windows, and found that scrubbing bubbles bathroom cleaner and the green side of a sponge does a great job of cleaning the rubber......then let dry, and then do the warm mineral oil.
Old Sep 13, 2019 | 08:08 PM
  #23
I goofed and made the update on the bottom of this thread, which was under a "Related Thread" "2.1 million color LED under car kit with 6 LED tubes". DOH! I hate those add-ons at the bottom of threads.......take too long to find and reload all the pics here. Maybe the "related thread" will stay on the bottom of this one?????
theiss2200
Sep 12, 2019 08:07 PM
akmorris
May 25, 2007 02:22 PM
eqnish
Apr 12, 2007 04:24 PM
dickey_jd
Nov 3, 2005 12:14 PM
kate
Oct 30, 2004 05:49 PM
