intermittent ignition problems with 1990 Montero
Old Sep 18, 2007 | 12:28 AM
matthew_m75's Avatar
Default RE: intermittent ignition problems with 1990 Montero
It's not the TPS or the MAP because you would still get spark. It could be the ecu but in my experience there were a lot of older fords that had a problem with theIgnition Control Module that this would happen where your engine gets up to temp and your ignition cuts out and stays out until it cools off. The Ignition Control Module could be in the distributor or on the fendor or the intake manifold. I dont really know on your car. Youcan probably find a pic on the kragen website so you know what to look for.
http://www.partsamerica.com/productd...94&PTSet=A
Old Sep 18, 2007 | 01:27 AM
e rock's Avatar
When it's hot and you have no spark, is there still power to the coil?
Old Dec 23, 2012 | 02:11 PM
RealCrops's Avatar
It sounds like the Ignition control module - or the connector to it being loose. Might need to replace/rewire connector, or replace the module. Had this issue in mine.
98Montero
Jul 8, 2014 08:43 AM
allallyouyou
Feb 12, 2012 11:13 PM
p4c0
Feb 22, 2007 06:36 PM
Doc37683
Jul 3, 2005 08:41 PM
Big B
Dec 31, 2004 04:47 PM
