Montero 2002 engine swap
Old Jul 30, 2013 | 03:20 PM
samoyedman's Avatar
Default Montero 2002 engine swap
Hi guys, thanks for letting me in. I was wondering what the difference between a 2000 3.0 and a 2002 3.0 is ? they are both sports. The motor is smoked in my 2002, and a ran across a strong 3.0 out of a 2000 sport. It looks like the long blocks are the same, but interchange says they are different. 8th digit on both vins say H. Any ideas would be great ! Thanks
Old Jul 30, 2013 | 05:53 PM
Akzle's Avatar
probably not a lot.
What model engine, 6g73?
Old Jul 30, 2013 | 07:59 PM
samoyedman's Avatar
It is a 6g72, I believe they both are.
Old Jul 30, 2013 | 08:00 PM
samoyedman's Avatar
They are both Montero sports.
Old Jul 31, 2013 | 04:18 AM
Akzle's Avatar
ok. So you want to put a 6g72 in a vehicle designed for a 6g72.
What was the question?
Old Jul 31, 2013 | 08:21 AM
samoyedman's Avatar
The Hollander interchange guide says they are not interchangeable, anyone selling a 3.0 says engine interchange stops at 2001, and will not swap with a 2002, I was wondering why before I get in to it.
Old Jul 31, 2013 | 03:02 PM
Akzle's Avatar
huh. I wonder if thats ecu related,
your only thing, if youre doing the swap yourself, go have a look, check engine mount positions, bellhousing size and shape. It will be pretty obvious if it wont fit.
Old Jul 31, 2013 | 04:32 PM
samoyedman's Avatar
It is the same block, casting # is the same for the heads on both blocks. I would think if I swapped all the accessories, intake and even the manifolds and sensors it should work. the casting wouldn't be different for the trans or motor mounts. Unless there are different holes drilled for sensors, water passages, or emissions, I don't see a difference. I just don't want to get 4/5ths in to into it, and then have that WHAT THE &%@# !!! moment !
Old Jul 31, 2013 | 10:41 PM
Akzle's Avatar
why bother swapping accesories? Or were you hoping to only buy the motor as a long block?
Wtf moments happen, regardless of how well planned.
JimmyB1901
14
Jan 8, 2018 09:03 AM
Dubious Jones
Jun 7, 2015 11:34 AM
eco.ramon@yahoo.com
11
Oct 4, 2014 06:44 PM
jar92365
11
Jul 26, 2010 05:34 PM
Dj_Renegade
Oct 23, 2009 10:55 AM
