Montero Sport gearing & options questions...
Old Oct 24, 2006 | 06:57 PM
off roader's Avatar
Default Montero Sport gearing & options questions...
I've heard some Montero Sports offer the larger rear pumpkin w/ OE Locker like those found in the 3.5L DOHC Montero SR model. I've also heard they'll fit either the 2.85:1 or 3.15:1 transfer case upgrade gears available from Australia.
Can someone confirm this for me, and if so, how can I tell if a sport I'm looking at has either.
Also, are any sport owner's running 35's or larger tires off road w/ the stock or slightly modified drivetrain?
TIA
Old Oct 24, 2006 | 07:21 PM
Manybrews's Avatar
Default RE: Montero Sport gearing & options questions...
the 3.5 sport does have a larger axle than the 3.0, although if its the same as the older montero I have no idea.
Old Oct 24, 2006 | 07:51 PM
off roader's Avatar
Is the front also the larger axle from the 3.0 Gen I Montero or the smaller one from the 3.0 gen II Montero?
Do you know which models I should be looking for if I wanted to buy one? Also was the locker an option? Was it standard on certain package groupings the way it came with the 94-96 Montero SR's?
Hmmm... maybe I'll get a newer sport instead of an older SR.
justin210485
13
Mar 24, 2015 11:59 AM
thewags
Feb 10, 2014 11:10 AM
estalilla
Aug 19, 2011 09:52 PM
sock puppet
11
Sep 23, 2009 08:05 AM
downhillspec
Mar 31, 2009 08:33 AM
