Montero Sport The left turn signal won't stop blinking
Old Jun 11, 2010 | 03:30 PM
2000MonteroSport's Avatar
Default Montero Sport The left turn signal won't stop blinking
I have a 2000 Mitsubishi Montero Sport LS. I was driving last night and made a left turn and used the turn signal. After I made the left turn when the turn signal should have clicked off it made a clicking sound but stayed on. I tried moving the turn signal arm to the off position and right turn position but the left signal keeps blinking and won't stop unless I shut off the car. The turn signal arm doesn't seem broken. Any help would be greatly appreciated.
Old Aug 7, 2012 | 04:15 PM
2000MontyLtd's Avatar
Default Turn Indicator Lever Switch
Problem solved by replacing turn indicator unit. The old unit had (tab broke off in normal wear and tear) a plastic tab that would allow switch to return to center after turning the steering wheel back to center position. It was hard to believe that Mitsubishi would allow such a fault in design. Hope this helps anyone that has a turn indicator blinking and won't cancel.
athlete1012
Jul 14, 2010 09:06 PM
98Montero
Oct 19, 2008 08:43 PM
athlete1012
Sep 12, 2007 10:40 AM
capecodder
Aug 4, 2007 08:32 PM
dornstar
May 22, 2006 04:58 PM
