Montero sport not shifting good after motor swap.
Old Jun 17, 2019 | 05:55 PM
autocraft's Avatar
Default Montero sport not shifting good after motor swap.
So i swapped a motor out on an 03 montero sport 3.0L since that the tranny will not shift up until high RPM. i feel like i left something off or got something crossed. motor runs fine otherwise and tranny had no issues before the swap. what am i missing? no check engine light or codes. btw motor was swapped out due to high kms and intermittent overheat issues.
Old Jun 24, 2019 | 03:49 PM
Check to make sure you did not miss some connector. Often it helps to physically disconnect each connector and re-connect it again. It may seat the contacts properly. Also check the grounds to the transmission to make sure it didn't get missed.
tdf46
Jan 20, 2019 02:35 AM
Outlander Matt
Dec 7, 2017 11:32 PM
cpluto3
Oct 26, 2015 08:29 AM
eddyhondro
Dec 1, 2011 10:22 AM
redturboeclipse
Oct 26, 2009 10:41 PM
