Are Montero's front wheel drive?
Old Sep 30, 2005 | 09:51 PM
6198max's Avatar
Default Are Montero's front wheel drive?
I am looking to buy a Montero and I was not considering 2wd because of winter driving. Does the 2wd do ok in this weather? Are they, in fact, front wheel drive?
thanks for you replies
Old Oct 1, 2005 | 01:59 AM
Joel_CA's Avatar
Default RE: Are Montero's front wheel drive?
All full size Montero's come with 4WD STANDARD and cannot be purchased in 2wd. If you are referring to the Montero Sport (a completely different vehicle), it is a RWD system. It comes with a "winter mode" switch that allows you to start forward motion in 2nd gear (reducing the likelyhood of a spinning your tires), but it may not be enough if the weather is severe enough. I'd highly recommend the 4wd or A4wd Montero Sports if you get very severe winter conditions in your area. Good Luck!
Joel, CA
Old Oct 4, 2005 | 11:49 PM
mitsu4x4nuts's Avatar
All montero sports are rear wheel drive and the full size monty are 4wheel drives
Old Oct 5, 2005 | 03:05 AM
Joel_CA's Avatar
The Montero Sports come in either RWD, 4WD or AWD depending on year.
Old Oct 16, 2005 | 06:39 PM
FireDoc's Avatar
Here in alaska, anything rear wheel drive is considered a summer toy.
Old Dec 11, 2005 | 11:53 AM
RacerX's Avatar
The Endeavor is a front drive so that may be an option as well.
sk8dudety
May 31, 2014 08:55 AM
Bob_G
Apr 11, 2013 11:25 AM
se4448
Oct 29, 2007 03:00 PM
micahman
Aug 1, 2006 09:52 AM
trbodsm997
Dec 25, 2004 01:52 AM
