Need new Motor for 1998 Montero
Old Jun 29, 2018 | 08:20 PM
DukusMaximus's Avatar
Question Need new Motor for 1998 Montero
I just bought a 98 Montero and it has 216XXX miles on it and is smoking a bit out of the tailpipe. My first thought is to drop a new motor in it. Obviously I don't want to drop a couple grand into a brand new engine, can anyone tell me first what engines will swap seamlessly into the 98 and second, where is the best place to look for a good used engine. Thank you all for your advice!
Last edited by DukusMaximus; Jun 29, 2018 at 08:45 PM. Reason: adding more information
Old Jun 30, 2018 | 06:08 AM
larry4406's Avatar
I looked long and hard for a used, rebuilt, or new motor when mine threw 2 rod bearings. Also could not determine the interchange with other models. In the end, I rebuilt mine.
https://mitsubishiforum.com/forum/mi...removal-48920/
If your engine runs well, but just smokes a bit, I suggest you replace the valve stem seals. If you are mechanically inclined, you should be able to do this yourself. There are ways to replace the valve stem seals without removing the cylinder heads from the engine.
Old Jul 24, 2018 | 10:41 AM
Sorry for the delay in responding, but thanks. I am about 3 days away from completing the top-end rebuild, and its going pretty smoothly. Looking forward to another quarter million miles or more!
Jackdavid
Mar 6, 2018 06:18 PM
futurescape
Jun 22, 2010 08:20 PM
importpreformance
May 3, 2009 08:06 PM
mxmikie
Jul 1, 2006 03:37 AM
Richie03
Dec 12, 2005 11:14 PM
