New 2003 Montero Limited owner with a question
Hi guys,
I just purchase a low miles 03 Montero Limited 3.8L with 120K on the clock... there's no history whether the timing belt has been done ( I assume not yet) so I wonder if there's a way to check the belt?
You can take off the plastic timing belt covers that are in front of the cylinder heads. This will allow you to see the condition of the belt (if its cracked, worn, etc). If you don't have a definitive confirmation on belt being replaced any time recently, plan on doing it ASAP. The recommended change interval on the timing belt is 60k. If it is original TB, you are 2x past the replacement requirement. Even if the replacement was done at some point near 60k - you are at another replacement interval. Get a Mitsubishi belt and tensioner, but have a good local shop do the job (unless you can do it yourself). This will save you significant amount of $$ vs having a dealer do the procedure.
Some people recommend replacing the water pump at the same time. I'm not in that camp. To me, if the pump is working, no overheating symptoms and no weeping of the seal - leave it alone. An old OEM pump is better and stronger than any cheap replacement you'll find. If there is anything I learned by owning a Mitsubishi it is this - replace ONLY parts that are bad (not the ones you think could use a change), and replace them with quality parts (OEM if at all possible).
Nikoni
11
May 28, 2024 05:25 PM
Brewcity1
Aug 15, 2018 12:16 PM
Sleepytiger86
Aug 15, 2015 11:49 AM
908ben
Jul 25, 2015 10:37 AM
