power antenna has no power.
Old Aug 4, 2016 | 09:12 PM
tom61's Avatar
Default power antenna has no power.
installed after market power antenna, When I turn on the radio I hear my relay click normally. The antenna doesn't move. Have 0 volts at antenna wiring. Checked all fuses they're good. Antenna goes up and down fine when connected straight to battery. My reason for replacing the antenna was the old one would extend fully and keep running and grinding so I know my wiring/ power supply was good at that time. Any advice please?
Old Aug 6, 2016 | 10:50 AM
guangui's Avatar
Take your old antenna and connect back again. See if it works. If it works, even if it grinds, the issue might be your new antenna. If your old antenna doesn't work, then you have an electrical issue somewhere. Maybe the relay, even though it clicks.
sohosun
24
Dec 5, 2023 04:11 PM
eclipse003g
Jul 8, 2009 04:00 PM
JNRmonterosport2002
Jul 12, 2007 01:10 PM
lingwall
May 18, 2007 12:39 AM
mickluva
Apr 13, 2006 09:32 PM
