Problem with alarm in Mitsubishi Montero Sport
Old Feb 4, 2012 | 04:57 AM
belchin's Avatar
Default Problem with alarm in Mitsubishi Montero Sport
Hello. I would appreciate if more experienced users will help me with my problem.
Last night it was freezing outside, around 22F. Suddenly I heard alarm of my Mitsibushi Montero Sport. Since there was no reason to believe in theft I did try all means to stop alarm. I succeeded it only after disconnecting the fuses from battery. Now as soon as I try to connect fused to battery the alarm goes on. What can I do?
Thanks
Old Feb 4, 2012 | 01:12 PM
N88888's Avatar
My mms is a '99 and without knowing your year I'm not sure...but
  1. put the fuse back in.....the alarm will begin sounding
  2. get in the car and close the door (not necessary to close the door but I do it)
  3. put your key into the ignition
  4. locate the 'red' flashing light on the left side of the steering wheel/column on the dash board.
  5. turn the key to the 'acc.' position (don't try to start it just to the acc pos.)
  6. while the ignition is on acc. press the red button/light and release. (the alarm should stop but the light will continue to blink
  7. Turn the key off and remove them
  8. Put the keys back in and start as usual.
That is my experience with my '99 mms...hope it helps
N8--->
Old Feb 22, 2012 | 06:54 PM
Obakemono's Avatar
Sounds like water got into the relay that controls the alarm. At least your alarm works, mine when on vacation for 8 months then just decided to return and start working again the other day. I wish my headliner light would get back from vacation as well............
JdpArv13
Aug 14, 2016 04:53 PM
edes101
Aug 14, 2016 04:41 PM
BelizeMike
Apr 12, 2013 12:44 AM
mhansen262
Nov 18, 2008 08:16 PM
victim619
Feb 25, 2008 08:33 PM
