Problems with 1997 Montero's read door
Old Oct 22, 2004 | 07:46 PM
Bob's Avatar
Bob
Default Problems with 1997 Montero's read door
Our '97 Montero SR read door can't be opened. Seems like this has happen once before, but it corrected itself. Has anyone else had this problem? Thanks in advance.
Bob
Old Nov 15, 2004 | 05:36 PM
DarkManC's Avatar
Default RE: Problems with 1997 Montero's read door
Seen this before at my dealership.You have a broken rear door latch and the interior panel on the inside will have to removed somehow.We have had to forecfully had to remove them here at the dealership.But that is your decision.
Old Jul 19, 2006 | 10:06 PM
jsevinsk's Avatar
The same thing just happened to my 2001 Montero. The latch is stuck. If I turn the key back and forth in the lock and jiggle the handle at the same time, I can eventually get the door open. I'm hoping it just needs to be lubricated. Has anyone tried this? Are there some holes for lubrication, or do I have to take the rear door apart?
John
Old Jul 19, 2006 | 11:04 PM
Rumplecat's Avatar
I also have a 97 Montero SR and I have had this problem many a times. I have experienced this when I go on bumpy roads. All I do is just lock and unlock a few times and it corrects itself. That is the only way I have found to fix it but it works so I really don't worry about it too much though.
scottsale74
Sep 9, 2013 12:39 PM
90LongBox
Sep 4, 2013 10:15 AM
photog3740
Mar 11, 2012 03:41 PM
jp2000
Jan 1, 2012 05:21 PM
J.Strandberg
Jan 28, 2011 08:00 PM
