To Rebuild Engine or Not
Old Apr 25, 2008 | 08:27 AM
kingarfer's Avatar
Default To Rebuild Engine or Not
My 2000 MS had the timing belt jump a tooth or two, and the result was extensive valve train damage and two pistons damaged. The complete estimate (from a highly recommended rebuilder) is $2575 for a complete rebuild (crank refinishing, pistons, valve train, oil pump, block/head renewed,etc). The vehicle is in great shape, otherwise, and it has 126k on it. I was late with the second timing belt change. The Mitsu dealer offered to buy it for $1500, or fix it for $7500.
My instinct is to go ahead with the $2575 repair, andblow my tax refund (plus some savings).
Would you do the same? Is there anything else I need to consider for the rebuild?
Old Apr 25, 2008 | 11:11 AM
Default RE: To Rebuild Engine or Not
I would personally look for a used motor. Much easier.
Old Apr 25, 2008 | 03:38 PM
tj90's Avatar
What was the mileage on the timing belt?
If you like the truck, its been maintained well and you can handle the gas prices, Id say rebuild and make sure there is a warranty that makes sense. Sure, the guy wont warranty a rebuild 50k miles, but at least something so that you are not throwing your money away if it burns oil or lacks power within the first months of driving.
Youll end up with a truck that has a "new" motor and will last years *IF* you keep up with your maintenance!
Old Apr 25, 2008 | 10:38 PM
jgbrules's Avatar
go with a used motor. you can find plenty of them with low milage. any salvage yard is hooked up with other salvage yards all over the country and can locate one very easily. just be sure to have whoever is doing the work to put on a new t-belt before the motor gets installed. average price for a used motor will run you 800-900 bucks.
Old Jul 13, 2008 | 09:50 PM
turfmonth's Avatar
What did you decide to do?
My timing belt just broke in my 98 MS Sport. The belt had 40,000 miles on it.
I called around my area and found a couple of shops who told me they could install a used engine (with 60,000 miles or less) for around $3100.
I finally found one shop who will install a rebuilt engine for $3400. 2 year/24,000 mile warranty.
I can't do the work myself, so those savings are not an option.
I'm going to go with the rebuild.
AznLibra929
Aug 6, 2007 08:45 PM
50ul }{4ck3r
Jan 24, 2007 10:25 AM
MoMoney57
Nov 1, 2006 02:09 AM
gst4me
May 18, 2006 03:42 PM
m3kgt_99
Jan 31, 2006 05:25 PM
