Reverse Problems
Old Jun 3, 2012 | 11:02 AM
Mr. Z.'s Avatar
Originally Posted by Suhaill
Yes, the dip stick is reading .5 inches above the hot line when checked according to your previous post
You can just drain out some from the transmission sump, but I wouldn't waste putting fresh fluid in until you do a complete fluid exchange.
Old Jun 3, 2012 | 11:24 AM
BigJoeRice's Avatar
Sorry wasn't clear......
Are there good alternatives that you can get at NAPA or O'reilly without having to get it from the Interweb.
Old Jun 3, 2012 | 05:09 PM
Mr. Z.'s Avatar
I can only recommend using genuine Mitsubishi Diamond ATF SP III.
There are products that claim to be compliant, however, I've heard some folks talk about problems after putting other ATF in their rigs.
Old Jun 3, 2012 | 05:46 PM
Suhaill's Avatar
i found this 10 Min Automatic Transmission Fluid Flush + Replacement (Most Cars) - YouTube , is ok to do it in this way?
Old Jun 3, 2012 | 10:44 PM
Mr. Z.'s Avatar
Yes, that is the general procedure. I would just reference your Factory Service Manuel (FSM) for the location of your fluid lines. I'd also recommend getting someone to help.
Have someone sit in the driver's seat and turn the key to engage the starter and pumps, but when the rig fires up, turn off the key. I don't suggest leaving the engine running when performing this service. Short bursts on the starter, until the fluid starts to run clean. Having a fresh washer to put on the drain plug is nice too.
Old Jun 7, 2012 | 10:10 AM
BigJoeRice's Avatar
I went with the Mopar +4 and so far its quieter, shifts smoother and picks up quicker. Of course the oil that came out could have been sludge as I have no records for the vehicle; so I could have put in cooking oil and got a result - but after a week it seems to be an improvement. It was also readily available and the same price as Diamond ATF.
Old Oct 2, 2020 | 06:43 PM
Baltazar Ladia Alegre's Avatar
Default No reverse
My Montero Sport 1998 (180,000 miles)
has no reverse in the morning or after it sat there for 1 hr.
What could it be?
no reverse
jp2000
Jan 1, 2012 05:21 PM
EclipseGST96
Aug 14, 2006 11:37 AM
SiCrIcAnRoLLa
Aug 4, 2004 03:41 AM
r0ck182sh0w
Nov 20, 2003 11:21 PM
GrindinGears
Jun 13, 2003 08:01 PM
