Running Weak
Old Feb 1, 2015 | 12:20 AM
Ronny300's Avatar
Default Running Weak
Hi
I have a problem with a Pajero -97 3.0 24v.
It always starts but when you press the accelerator pedal while driving so it does not happen so much. The engine has no power. If you make a kickdown it takes a very long time before it comes up to speed. And it loses power on the slopes when driving.
Feels like chewing gum if you know what I mean.
I changed the timing belt, spark plugs, and water pump just, but the error already existed before.
I bought the car unseen from a car dealer in Northern Sweden with a cracked manifold. It is fixed. The dealer did not know much about the car.
Anyone have a good tip?
best regards
Ronny
Old Feb 1, 2015 | 01:34 AM
Akzle's Avatar
compression/ head gaskets.
Old Feb 1, 2015 | 06:41 AM
mxmikie's Avatar
pull the fuel pump from the tank and check the hose from the fuel pump to the pipe it is about 3 inches long they rot and cause a loss in fuel pressure creating your symptoms
Old Feb 1, 2015 | 03:33 PM
I agree with mxmikie - sounds like a fuel delivery problem.
Old Feb 2, 2015 | 03:50 AM
Ronny300's Avatar
Hi,
Well maybe it is a fuel problem, I didn't see any leaks on to pipes at the fuel sender unit but when I try to losen it, it snap off. So now I have to fins a new one :-(
Old Feb 2, 2015 | 02:33 PM
Ronny300's Avatar
A little update,
Took the fuel pump assembly from my -94, replaced the hose from the pump to the fuel filter.
Fitted it with a new catalyst.
But .... no difference.
It has perfect idle, and starts instantly.
It runs best at low rpm, but as soon as you try to accelerate it happens almost nothing. If I make a kickdown so it accelerates but not as it should.
If I give it gas stagnant, I think that it behaves fairly normal.
It has a fairly high intake sound, but I have on my -94 too, and it works fine.
Then I have a strange sound in the engine compartment, it sounds a bit like a fishing boat.
And finally, there are no error codes.
I'm going crazy ....
What could it be? EGR ?, throttle body?
Old Feb 2, 2015 | 11:53 PM
Akzle's Avatar
humor me .
Old Feb 2, 2015 | 11:56 PM
Can this be caused by exhaust back pressure too high?
Old Feb 3, 2015 | 04:44 AM
Ronny300's Avatar
What would cause that?
Old Feb 3, 2015 | 05:33 AM
2001Mitch3.5XS's Avatar
Just for ****s n giggles why don't you take the temperature of the front and back of the catalytic converters and let us know... stumped here !!!!
