Running Weak
Old Feb 3, 2015 | 03:20 PM
Originally Posted by Ronny300
What would cause that?
Running super rich and melting down the honeycomb material inside the cat.
Old Feb 4, 2015 | 11:23 AM
2001Mitch3.5XS's Avatar
I am thinking the same thing here. I would love a temp reading off of them.
Old Feb 5, 2015 | 12:24 PM
mlduncan96's Avatar
This sounds exactly like what I am dealing with, except I get a couple codes. It sounds like I have a few more fuel lines to examine. My evap system has a gross leak because of the lines alongside the fuel filler neck are corroded. I am putting in an order tomorrow for new ones, but first I will try to examine the line to the fuel filter. Please let us know what you find.
I have replaced timing belt, water pump, plugs, plug wires, ICM and thermostat. Under load/torque/hill it loses power and feels like surges in power. Also tried looking for intake leaks with starting fluid. I have noticed the vacuum pressure drops to about zero when the power surge begins. I am monitoring with bluetooth OBD and Torque Pro app.
Old Feb 5, 2015 | 07:10 PM
Vacuum should be going down to zero when at wide open throttle. Max vacuum at idle, minimum at wot.
Old Feb 6, 2015 | 03:02 AM
Ronny300's Avatar
"mlduncan96" good that someone else has the same problem.
Today i am going to change fuelfilter and clean the gastank.
I also tried yesterday with another throttle body without any luck.
Old Feb 6, 2015 | 08:44 AM
Ronny300's Avatar
Nope, no luck with todays work.
Its only work fine over 4500 rpm, less its like chewing gum.
Crankshaft/camshaft position sensor maby?
Old Feb 6, 2015 | 04:58 PM
Ronny, have you tested your throttle position sensor and MAF sensor? I'm not suggesting to replace them, just test them.
Old Feb 10, 2015 | 12:22 PM
Ronny300's Avatar
Today I took the time to do the compression test.
It was 12,2kg of each cylinder. Nothing wrong there.
It, however, I observed was that the intake gasket was greasy and it's very fouled in the intake.
I was out and test drove and when I got home, I checked the exhaust values.
145 HC and 13.8% co2.
After I had revving up it properly for a while became the values back to normal.
32HC and 14.9 co2.
It clearly has problems with combustion.
I'm starting to lose the desire to continue soon.
Old Feb 10, 2015 | 01:37 PM
mlduncan96's Avatar
My new evap/fuel filler lines are on their way. Should be here by weekend. I was thinking of picking up a can of valve cleaner I saw on the local parts store shelf on the way home today thinking maybe a small deposit was keeping one from closing completely. After reading your post I am now wondering if this is a clogged catalytic converter. You have done far more than I have to determine what is going on.
I noticed my throttle body was very oily/greasy along with the intake. I wondered about the PCV valve. It looked rather dirty also, but seemed to move freely. I may go ahead and change it anyway since they are inexpensive. I had planned to clean my throttle body, but it didn't improve anything for yours, Ronny. I am down to thinking airflow backed up in the exhaust.
Old Feb 10, 2015 | 10:54 PM
Ronny300's Avatar
Where did you buy your EVAP pipe?
Last night as I stood in the garage and thought, and turned and twisted intake plenum, I saw that channel from the EGR valve was completely clogged inside the plenary.
It was a hell of a job to get rid of all the crap. It was completely blocked.
Thought I had found the problem, but no.
Exactly the same thing except to the EGR valve is working properly.
