Start and idle problem
Old Oct 31, 2019 | 03:41 PM
Nashied's Avatar
Default Start and idle problem
Hi, I have a 2000 pajero blister fender, so the van was driving and staring perfectly fine I use it daily, however i have been driving with cracked exhaust branch manifold. I managed to fix it, now the vehicle don't want to start unless I jump start it and also the idle is irregular now. When I switch the vehicle off and turn on the ignition to start again then dashboard lights burn strong but the vehicle don't start unless I jump start. What can this be.? Please help.
Old Oct 31, 2019 | 05:29 PM
How did you repair the manifold?
Old Nov 2, 2019 | 03:52 AM
Nashied's Avatar
It's exhaust branches I took it to a exhaust fitment centre
Old Nov 3, 2019 | 01:53 AM
Ok, thank you for clarification. The reason I asked - if you welded them while on the vehicle, you could have blown out PCM. Sounds like we can eliminate that for now. First things first - double check your battery contacts (both positive and negative). Check to make sure your grounds on the engine are good. Did you reconnect all sensors properly? Might be worth unplugging and replugging them to ensure the contacts are good. And of course - check the battery condition and cgarge
Old Nov 6, 2019 | 11:50 PM
Nashied's Avatar
I managed to replace the battery and drove for two days and everything seemed normal again, when suddenly it done the same by not starting then I Jumpstarted it and it started I drove for abit and it died again asif the battery wasn't getting power.
Old Nov 7, 2019 | 10:31 AM
Check your battery connectors and ALL grounds. Corrosion at connectors may inhibit current, especially at lower temps. You can try to start the engine and with it running, disconnect battery terminal. If engine dies - you have some issue with the charging system.
02mitsuecli
Jan 20, 2019 07:05 AM
wilde
Dec 9, 2017 03:52 PM
cruisingthesouth
Jan 23, 2008 05:29 PM
naruto454
May 24, 2007 05:22 PM
yamahablaster8230
Aug 29, 2006 09:28 AM
