Stuck crank gear. 2001 Montero sport ls 3.0 v6 sohc
Old Dec 3, 2011 | 03:42 PM
Fpdhound's Avatar
Unhappy Stuck crank gear. 2001 Montero sport ls 3.0 v6 sohc
Maybe someone has had this problem, after removing the harmonic balance/pulley (which came with ease surprisingly) the crank gear won't budge from it's spline (yes the sensor was removed prior to the attempt). Can anyone help me out, is there a tool that will make this easier without damaging the sensor plate behind the gear?
Old Dec 5, 2011 | 06:39 PM
Fpdhound's Avatar
Nevermind, PB and a couple of screwdrivers with a 2lb brass hammer did the trick. I bent the sensor plate "couldn't be helped in this case" it was a ten dollar replacement. Timing belt job is done. Thanks anyway.
Shadowplane676
Jul 7, 2021 07:50 PM
Tbert
Jul 28, 2014 11:25 PM
incabid
Nov 10, 2006 06:28 AM
Doober247
Apr 3, 2006 08:10 PM
Jdg784
Jan 22, 2006 05:01 PM
