Tips on changing timing belt its 2001 3.0 sport
Old May 23, 2008 | 07:42 PM
aviator79's Avatar
Default Tips on changing timing belt its 2001 3.0 sport
OK so could not find what iwas lookingfor so I started anew thread, can someone tell me what the size of the crankshaftbolt is, so I can go buy the socket. Any other special tools I need? as I dont have all my tools so I only have like up to a 19mm socket. I thought I read it was 1 1/16" but not sure.Also how do you find TDC as it doesnt have a distributer? I didnt see one to buy so assumed it does not have one. Haven been under the hood much yet, but need to replace girlfirends timing belt. Do I need to remove spark plugs to change the timing belt? I assume to be able to turn crank I would, but Istill dontunderstand how to find TDC with just taking plugs out.I didnt get my wiresyet and dont want to have to remove the spark plugs without them as I see it is a PITA so I guess I will just have to wait.
Also I only bought the belt and water pump. Should have I bought a tensioner and whatever else. Please help.
Montero newb
Thanks.
Old May 23, 2008 | 08:02 PM
carlover626's Avatar
Default RE: Tips on changing timing belt its 2001 3.0 sport
I can't answer all of your questions, I had mine done. You won't need to remove the spark plugs to change the T-belt, different areas completely. I understand there is a "special" tool needed for the crank bolt...to keep it from turning while you tighten the bolt.Change the tensioner (for sure) and other 2 drive belts (if needed) while you are in there. Have a look at the cam/crank seals too, they could need replaced if they are leaking.
Hope this helps, sorry I don't have more detailed info. Someone else may chime in.
Old Jun 22, 2008 | 12:30 PM
mxmikie's Avatar
http://www.gates.com/brochure.cfm?br...&go=TBHome
mirrormirageman
Apr 4, 2015 04:40 AM
Coqui_Mitsubishi
Jun 12, 2014 10:05 PM
2005OZ
Jul 20, 2011 01:46 PM
Obakemono
Mar 27, 2010 11:18 PM
tom93
1st Generation
14
Oct 29, 2008 01:59 PM
