transfer case indicator lights flashing!!!! please help!!!
Old Oct 26, 2022 | 06:11 PM
  #31
goWest's Avatar
Originally Posted by Mr. Z.
I recently had a flashing transfer case light on the '02 Montero. Before even pulling the codes, I crawled under the rig to inspect each plug connection. These are exposed to a lot of debris over the years, and although they are weather-proof connections, they can corrode and/or become loose. One at a time, I disconnected each plug and cleaned the contacts. Then plugged them back in with some dielectric grease. That's it! No more flashing transfer case lights.
...hope this helps.
Cheers
Mr. Z, you are my hero, I just got a 2002 Montero LTD, good condition, so I’ve been tracking your replies and contributions. My C/D orange light has been blinking almost 15 miles into my trip, usually just on the freeway for some reason, and after I turn the engine off and restart, the light resets, but comes on in 15 miles again. I’m going to try to crawl under and look at the sensors and connectors myself. My question is, can I do this on my own without a car lift (I’m not a mechanic), and once I get down there if I am able to, I can probably Google to see where the connectors are, but would love a link or instructions of any kind, so that I can possibly save some money! Anything you can tell me will probably help, thanks again!
Old Oct 27, 2022 | 07:39 AM
  #32
Mr. Z.'s Avatar
The connectors are located on the rear of the transfer case, near the top of the case, on passenger side of the output shaft. You'll see four (if I recall correctly) connectors. They're a bit hard to get to, but I just crawled under the rig in my garage with a flashlight. The connectors will all be in a row next to each other. Unplug them one at a time, clean the contacts (I used some 600 grit sand paper and a pick to get them shinny), then apply some dielectric grease. Be sure the plugs snap back in snuggly.
...hope this helps.
Cheers
Old Jul 29, 2024 | 02:27 PM
  #33
hhughes0320's Avatar
ground pin1 to pin4 on code connection for OBC.
Old Jul 30, 2024 | 07:53 AM
  #34
ACJ MONTI's Avatar
Originally Posted by jhill15
I just bought my 03 limited yesterday drove it about 20 miles in 2High, stopped and turned it off. When I got back in and took off "still in 2 high" about 1/2 a mile down the road the transfer case lights on the dash started flashing. At first while the 2 rear wheels were lit green just as they should in 2 high the 2 front wheels started flashing green. After about another 1/2 mile all lights on the transfer case indicator disappeared and the center diff lock light started flashing. I stopped and tried switching the gear from 2h to 4h, 4hl, 4llc, i could move the shifter but it would not indicate it on the dash the cdl light just kept flashing, so I pulled off the road turned off the truck and started it back up...all is good, and everything has worked fine since.
Any thoughts????
Thanks
Hello,
Ive had a very similar problem with my 2002 montero. I found that replacing the vacuum lines to the 4wd system fixed this problem. Most likely you have a vacuum leak that is causing this.
Djabelnyc
Jan 19, 2011 05:22 PM
EVO4L
Mar 1, 2009 12:05 PM
thehintons06
Nov 27, 2006 02:25 PM
bugman12
Jan 7, 2006 12:49 AM
yura
Aug 20, 2005 11:00 PM
