Unknown Balls (Timing belt repair)
Old Aug 8, 2022 | 06:32 PM
Mike Gyver's Avatar
Red face Unknown ***** (Timing belt repair)
I have 2000 sport 3.0 Monjero of course, bought new and never changed timing belt. In May 2022 and 316,356 miles it finally broke. Put new water pump (part of kit with belt) New A/C compressor. Put front plate back on and new belts. Then horror, I saw 3 what looked like ball bearings on driveway. The sizes are 3/16" or 5 MM (close) no clue where there from! Any ideas. PLEASE! I don't want to finish without knowing.
Old Aug 12, 2022 | 08:50 AM
Firstof all... 316k on original timing belt is impressive. Hopefully you avoided valve/piston damage after breakage.
As far as small ***** from a ballbearing, most likely they come from tensioner and/or idler pulleys. If not, then it can be from anything else up front - alternator, steeting pump, AC compressor, radiator fan clutch mechanism. You going to have to check every rotating piece up there to see if any bearings are falling apart.
Old Aug 12, 2022 | 03:02 PM
Mike Gyver's Avatar
Checked everything I could without taking front plate back off, may have to. Not sure they are from a bearing and all under the plate look like they were sealed. My guess is maybe a back flow preventer from one of the lines I had to remove, or the new a/c is oil filled and the pully has three holes in front and their used as wedge to keep the oil from spinning out in shipping. I even checked all my tools. I am a diehard "If it ain't broke don't fix it" dude. Luckly that year was not an interference engine. I thank you for your feedback anything could help.
Old Aug 15, 2022 | 11:12 AM
Mike Gyver's Avatar
Solved!! One of the wheels on my mechanic's stool has issues and slowly losing them.
Old Aug 16, 2022 | 12:43 AM
Good outcome. Better than loosing ***** from anything on the engine 😅
98gstspy
Nov 2, 2007 08:04 PM
5Tizzle
Apr 5, 2006 09:17 PM
BigMoody1
Jan 5, 2006 12:34 PM
EclipseBabe29
Nov 21, 2005 09:55 AM
baker_sk8er37
Feb 25, 2005 08:57 PM
