Weird problem, 4Wheel light indicator, passenger rear NOT on, but no error codes
Weird problem, earlier I had to brake really hard and the ABS went on.
Soon after I noticed the 4wheel indicator, which was just set to normal RWD operation, only had the driver side green tire on, but the other was not.
I switched to different 4wd modes and everything worked normally but the light still did not turn on.
My ABS light did not go on, nor did any check engine or brake warning lights.
Could this just be the bulb in the indicator going out?
kostovski.dragan
Jul 30, 2014 04:55 AM
Simple3x
Other Mitsubishi Models
May 15, 2014 05:03 AM
bxdiamante
Jun 22, 2005 10:33 AM
