Weird problem, 4Wheel light indicator, passenger rear NOT on, but no error codes
Old Jan 28, 2010 | 08:26 PM
redturboeclipse's Avatar
Default Weird problem, 4Wheel light indicator, passenger rear NOT on, but no error codes
Weird problem, earlier I had to brake really hard and the ABS went on.
Soon after I noticed the 4wheel indicator, which was just set to normal RWD operation, only had the driver side green tire on, but the other was not.
I switched to different 4wd modes and everything worked normally but the light still did not turn on.
My ABS light did not go on, nor did any check engine or brake warning lights.
Could this just be the bulb in the indicator going out?
Old Jan 29, 2010 | 09:24 AM
jrmdir's Avatar
+1 on the burned out bulb. They don't last forever.
Swap it out with the either the "2" or "L" bulb in your shift position indicator if you don't want to buy a new bulb just now.
Ron
Old Jan 31, 2010 | 06:52 PM
I fixed the problem, I just hit the dash with good force and it came back on. lol.
Old Sep 15, 2014 | 03:39 PM
deadreckoning86's Avatar
i had the same problem with mine but it also made a horrible grinding noise with it to but have no check engine light. also car drives just fine and has not made the noise since but the green passenger light is off too. does anyone have a guess on whats going on????
kostovski.dragan
Jul 30, 2014 04:55 AM
Simple3x
Other Mitsubishi Models
May 15, 2014 05:03 AM
clattin
Jun 27, 2013 06:14 AM
bxdiamante
Jun 22, 2005 10:33 AM
get435
Oct 17, 2004 10:09 AM
