what type antifriction grease is used in our turnsignal switch
Old Nov 22, 2022 | 03:35 PM
PalmSprings's Avatar
Default what type antifriction grease is used in our turnsignal switch
Ihad to replace my turn signal switch assembly on my other 01montero sport (@ .(150K ).
.because the right turn signal would remain on all the time the ignition was on...couldnt shut it off unless I held in the flasher button. (FYI: My other one with close to 240K ,works fine, since new.)
My question : what anti friction white lube is used in the switch ? I can easily see white grease in the one I replaced but the new one either doesnt have any,or is hidden from view even after I moved the handle a couple times. I cant be certain it was pre lubed now . There was no information about it.. and it comes from Tiwan thru amazon.
The one I removed had it all over the visible parts that were in contact when moving the signal "stick"
How'bout lithium? That may be what I choose if nothing knew is learned . How about teflon white grease. I have a 1/2 cup of it already. Itd be nice to not be stuck with more white grease I rarely use
jdohe
Jul 12, 2012 11:59 PM
happyharold4
May 28, 2011 05:20 PM
2000MontyLtd
May 7, 2011 10:26 PM
tyson724
Dec 16, 2008 08:00 PM
athlete1012
Nov 24, 2007 07:37 AM
