window repair? Replace?
Old Feb 16, 2020 | 10:53 PM
STEVENONER's Avatar
Exclamation window repair? Replace?
Hello to all...... I am a proud owner of a 2004 Mitsubishi Montero Limited , picked her up off the showroom floor @ Whittier Mitsubishi , My drivers side window is making a scraping noise as it goes up or down, it will get stuck around 1/2 ways down. I have searched for any info about this issue but did not come back with any results, I would love to take care of myself if I can, just not too familiar with the way the actuator works... any help would be greatly appreciated. Thanks...
Old Feb 17, 2020 | 11:28 AM
You can try to remove door trim and to lubricate the window lifting mechanism. It will make things move easier. Check to make sure that all the bolts holding the window lift mechanism are tight and not missing. Missing bolts will cause misalignment and can lead to window sticking. If none of those things resolve the issue, you may need to repair or replace the window lift motor.
Old Feb 17, 2020 | 03:01 PM
STEVENONER's Avatar
Thanks for your response... I oiled the rail and it seemed solid.... After looking into it , it seems the wire may be broken or is going to break very soon.... Can it be replaced by itself? Or is it sold as a unit? I'll do some more research .... But I've been coming up with nothing. I may have to bite the bullet and take it in. Thanks again Bro.
Old Feb 17, 2020 | 03:05 PM
I doubt you can replace a specific part of the mechanism. Its probably a single unit. I have no idea how much that will cost. You can try to salvage one from a wrecking yard if you can find a similar model. Probably 2001-2006 years for full size Montero should work.
Old Feb 18, 2020 | 12:56 AM
STEVENONER's Avatar
Thanks again.... I will post what was the problem and solution..... And most importantly .... How much $$$$. Very soon!
Old May 26, 2022 | 02:40 PM
Tobra's Avatar
Same problem, sprayed rubber window scrapers with silicone spray, problem solved.
kihapet
Oct 20, 2019 02:55 AM
tomopdyke
Oct 2, 2009 10:00 PM
ajan246
Sep 21, 2007 04:56 PM
rally king
Jan 4, 2005 09:01 PM
99spyder
Apr 10, 2004 03:20 AM
