Wont turn over
Old Jun 18, 2020 | 10:29 PM
debodezine's Avatar
Default Wont turn over
Hi...I am new to this..I have a 1995 Montero that I just got few months ago...was running fine then started acting like battery was dead the negative cable at the battery was in bad shape so got a new one only it's a normal cable..the guy at the parts store said it didnt need the 3 ground points...but with the new cable n battery when you put key in and turn on the lights come on but that's it try to start it nothing...wont even run the windows...any ideas be great...thank you
Old Jun 19, 2020 | 12:03 AM
What did you do with the connectors that were going to the other 2 points? Are they connected to good grounds? You csn tun additional simple negative wire to them. Depending on where connections are, there might be a reason why the original negative wire ran there.
markschu63
Jul 27, 2019 04:43 PM
Monteroman1994sr
Sep 23, 2016 11:57 PM
khmatilda
Aug 4, 2009 01:32 PM
hondo21
Aug 13, 2006 12:43 AM
jcaswa123
Mar 10, 2006 09:50 PM
