XLS 4WD light indicator question
Old Mar 28, 2008 | 10:26 AM
aws147's Avatar
Default XLS 4WD light indicator question
I am looking at a 2003 Montero XLS to buy from a local dealer. When I started it, the 4WD light in the dashonly has the driver side rear tire lite up. When I engage the 4WD both front tires lite up, but only the driver side rear. Is this a sign that something is wrong in the rear end? Any help would be appreciated.
Old Mar 28, 2008 | 06:38 PM
carlover626's Avatar
Default RE: XLS 4WD light indicator question
It could be that the bulb has burned out in the dash.
I dont have those lights in my MS, butI would think it should light up like the rest. Don't walk away with it till that is fixed though...
Old Mar 29, 2008 | 12:20 AM
jgbrules's Avatar
those lights burn out all the time. it wouldnt surprise me if none of them worked!! LOL!! you have to remove the instument cluster to replace them. you have to get those bulbs from the dealer. they come withthe socket so all you do is turn it and remove. not a hard job!! good luck!! greg...
kostovski.dragan
Jul 30, 2014 04:55 AM
greengrounds
Jan 20, 2010 06:59 PM
chelo
Jun 11, 2008 08:47 PM
jcasaccio
Mar 23, 2006 12:33 PM
varso
Sep 16, 2004 11:41 PM
