'05 fog lights
Old May 15, 2007 | 01:38 PM
AWDrivin's Avatar
Default '05 fog lights
I just installed the oem fog light kit yesterday but they don't come on. The oem switch on the dashborad lights up, there is power in the relay (checked with test light), and all connections are clicked/snapped in place. However, I am not getting power from the first connector after the fuse box (the driver's side fog light connector). What does everyone think it could be? A bad wire or something else? Can anyone help me out with this problem? What, if any did I miss or should do as well? The bulbs are fine.
Old May 15, 2007 | 06:35 PM
antlip's Avatar
Default RE: '05 fog lights
Make sure its grounded right. Check the bulbs. Check for splices in the wires. Just retrace your steps.
Old Jan 14, 2013 | 01:53 AM
catacami's Avatar
Wink
Originally Posted by antlip
Make sure its grounded right...
Yes, you're right. it was happen when i installed for my wife a new fog light kit. After adjust and tighten up the ground to the metal part. It works fine
Jims M
May 1, 2011 07:52 AM
blueb16
Feb 27, 2011 01:33 PM
thecrowforever
Apr 14, 2008 02:38 AM
wookie
Aug 8, 2005 02:29 AM
hyperkiper11
Aug 25, 2004 12:04 AM
