'05 fog lights
I just installed the oem fog light kit yesterday but they don't come on. The oem switch on the dashborad lights up, there is power in the relay (checked with test light), and all connections are clicked/snapped in place. However, I am not getting power from the first connector after the fuse box (the driver's side fog light connector). What does everyone think it could be? A bad wire or something else? Can anyone help me out with this problem? What, if any did I miss or should do as well? The bulbs are fine.
Yes, you're right. it was happen when i installed for my wife a new fog light kit. After adjust and tighten up the ground to the metal part. It works fine
