07 Outlander- Idle Adjustment
Old Dec 3, 2015 | 11:29 AM
con's Avatar
con
Thanks. I did see this before but the nearest dealer is 700kms away.
Old Dec 3, 2015 | 11:33 AM
gggplaya's Avatar
any garage with a j2534 cable can program it, thats the reason for the j2534 standard.
Old Dec 4, 2015 | 08:36 AM
con's Avatar
con
I have that cable from when I worked on my old Nissan sentra. do I need special software?
Old Dec 4, 2015 | 08:52 AM
gggplaya's Avatar
Only certain ones are compatible, most of the cheap ones are the bosch MVCI cable, so it's possible it'll work. Though in order to get it to work with toyota's software, a registry tweak was needed for me, so that may be the same for mitsubishi's software as well.
1. Go here and read carefully: https://mitsubi****echinfo.com/epacarb/
2. At the top click j2534 pass thru.
3. Read carefully then scroll to the bottom and click "detailed flash procedures". Then enter your VIN number.
4. Read the instructions and download CAN pass thru software somewhere in the middle of the page.
5. Check if the can pass through cable is working on your PC with the software.
6. If it works, you should be able to connect to your car and check your PCM hardware version number and the software installed on it. From the chart i originally linked, you should be able to see if it's out of date and needs updated.
7. If it needs updated, you'll need to subscribe to the mitsubishi website, it's $20 for 24 hours. From there you can download the TSB procedure and download the correct software you need. Then upload it via the CAN pass thru software.
killebrew
Mar 15, 2021 07:45 AM
quixmac
Sep 8, 2012 10:03 AM
3000gt16
Jul 3, 2010 09:03 AM
yahcoy
Nov 23, 2007 04:42 PM
bmwadam
Oct 3, 2007 04:46 PM
