08 Outlander
Hi,
I have a 2008 Outlander ES 2.4L, 58000 miles. Last Sunday I blew a lighter fuse while plugging my GPS. I started the car, the engine works fine but the ASC off light and the check engine light came on, there is no drivability. On the OBD2 scan tool P1590 and U0101 codes come up. I tried to drive it but it was very slow. I read a few posts for the same problem due to the same reason but they didn’t explain clearly what was done to fix it.
FYI, I already changed the lighter fuse and it is was not cold in Canada (about 18 degree C) when that happened. By the way I am in Canada
some suggestions would be appreciated. Thanks in advance
thanks Ccernst,
I tried it but it doesn't work. I will take the car to the dealer.
I've been searching on the web,it seems like many people had the same problem but they don't remember what was done to get it fixed. I am wondering what a blown lighter fuse has to see with ASC off and the p1590. U0101 codes.
Hi all
First post not sure if in right place but here goes,i have a freelander td4 03reg and was going to get a outlander but was wonder if you could give me a few things to look for when buy it and also could you tell me abit about the 2.0 diesel engine (how makes it,timing chain or belt etc).
Cheers kevin
Cheers kevin
seehow
May 12, 2015 05:08 PM
catherineapop
Dec 18, 2012 01:07 PM
ProcessorHog
Mar 28, 2012 07:07 PM
