2004 outlander cooling problem
Old Jul 21, 2009 | 02:11 PM
parpoura's Avatar
Smile 2004 outlander cooling problem
Hello guys i need your help i have a leak in my cooling system from the radiator to the bottle ,every day i see arroung 3 oz of coolant i take them and poor them back in the system if i leave it the water accumulation will go higher.
i changed the water cap and my mechanic said that the water valve is ok .
the fans works normally ,the engine is not overheating ,everything is ok in the car .
any imput will be much apreciated .
Thank You
Old Jul 21, 2009 | 03:25 PM
azjake's Avatar
When your mechanic said the water valve was ok, was he talking about the radiator drain plug? I think there's an o-ring there that could be the source of the leak. Another possibility is a small pin hole, or crack in one of your radiator hoses.
plomaman
Sep 16, 2012 02:13 PM
Hendo
Feb 19, 2011 05:40 AM
rjr234
Jul 16, 2009 05:14 PM
hara_ca
May 25, 2007 08:09 PM
jdmitsu
Sep 17, 2006 06:51 PM
